Update the rover icon in the map
Can we get the rover icon in the map to show the attached module? Even though I have the mower module attached, the icon shows Yarbo with the SAM attached. As such, when I’m trying to place no go zones using the templates it’s somewhat difficult to approximate how much distance is between the front of the icon and the front of the actual mower module.
This matters as when trying to place the template shapes I use the rover to locate where in the map the zones should go. i.e. I drive the rover up to a tree where I need a no go zone to the point where the bumper is almost touching, make sure the center line of the body of the rover is pointing to the center of the tree, and then place the zone in the map based on the rover’s icon.
this would seem to be a relatively trivial thing to change, but would be helpful for mapping.
I found it easier to first draw the NGZ then drop the templated one inside what I drew. Yes it’s duplicate labor, but the circles I draw with Yarbo aren’t very circular. :wink:
I do the same. and you can do it from the couch. :grin:
That sounds like a lot of work. Can you come do it for me? :joy:
That’s ok, the ones it cuts have more notches than 8-bit Nintendo. :slight_smile:
I would do that, but I found that it tends to tear up the grass pretty good at the base of the tree when you’re trying to do something less than about 3 feet in diameter…
Sure thing… bring your yard on down.
Sounds like more work. Maybe after my nap. :joy:
Hi there, thanks for sharing your suggestion. I understand your need for this feature. If more users share the same interest, I’ll help pass this to our product team for consideration.
Im of the same boat.
Living o er an hours drive from where both of my Yarbos are deployed it is a but of a PITA trying to set NGZs.
I know I have a couple that need moved.
