when i try to switch from the yarbo mower module to snow blower module, the app replaces the mower module with the snow blower module in the app. i then have to find and download the pathways and work areas for the snow blower module. i lose all the settings for the mower module. how do you set up the device so the app keeps the mower module with all settings and work areas intact in the app, and adds another entry for the snow blower to include its settings and work areas in the app?
This is by Yarbo’s design. You shouldn’t lose any settings, work areas, pathways, etc for in the app. You just can only access settings for the specific module that is attached. You remove and reattach a different module, those modules settings are accessible again.
I would suggest you check out Yardstick. It solves a bunch of these issues.
the problem i have is that it doesn’t add a new entry for the new module attached, it overwrites the entry for the module that was attached. what does the first screen of the app look like when you have both the mower and snow blower modules available? is there one entry for the mower and a second entry for the snow blower?
The very first screen when you open the app is a list of cores associated with your account. It will display the currently connected module there. That will change based on what is attached.
i prefer not to be held for ransom when purchasing items. i see you only offer a subscription model for yardstick. this doesn’t suit me. i would like to purchase the features available at the time. if new features come available i would like to have the option of purchasing them, or not, while still being able to use the features i paid for.
Understood. I’m just a Yardstick user. After you’re familiar with the Yarbo app feel free to revisit this thread.
This is the way it works. The picture updates based on the attached module. The core stays the same and all map elements like areas, no go zones, pathways, etc stay and the module specific stuff is populated. For example, the snow blower, you see any sidewalks that you created before. You won’t see those with the mower module attached. If you had a second Yarbo, then you would see that in the list there as a second unit. Or if someone shared theirs to your account, you would see theirs but it would say shared.
i’m quite familiar with the app, and am very computer literate. i believe there is a problem with communication between the app and the machine/modules.
when i switch between modules, the maps and settings don’t switch to the attached module. how do i get them to switch?
Could be, but your tone is less than inviting. Did you power down your core before switching modules. Hot swapping can cause issues.
Maps should be the same regardless of the module. You can adjust the settings for the snow blower areas under the area settings. Either by entering your yard and editing the map or go into settings, area and select the area you want to adjust snow blower specific settings for.
didn’t mean to exhibit an attitude, just wanted to be clear about my problem and capabilities.
i tried both the power button and disconnected and reconnected the battery on the core. the problem may be with when i’m powering down. do you power down with the old attachment still connected or after you’ve disconnected the old attachment? when do you power back up again, before you connect or after you connect the new module?
when you want to add the new module do you click the ‘+’ button at the bottom of the screen or just accept the defaults that come up with the attachment?
You’ll want power down before disconnecting the current module. Connect the new module and then power back up. After the core fully reboots, the app should recognize and show the current module. Let us know what you see.
thanks for the help. when i power down with the power button, do i just click the button or click and hold the button? if i click and hold, for how long. does the machine say its powering down or do the lights flash red to show its powered down.
Generally, power down from the App. Settings and then all the way at the bottom is Restart Yarbo System.
Edit: Choose Shutdown Yarbo
thanks. i shut down the rover through the app while the machine was attached to the mower module. i disconnected the mower module. i restarted the rover and moved it to where i have the snow blower module and connected it. it recognised that i had changed modules to the snow blower. the maps did not change, still shows the mower work areas, but the area settings changed to the snow blower settings. how do i get the maps to change?
i couldn’t power back up through the app, the restart button was greyed out. i restarted the rover with the power button.
Correct. You’ll need to power up from the back button. Forgot to mention that.
You’ll need to map the new areas the snowblower will handle. I’m assuming you haven’t had it connected before and obviously they will be different than the areas you mow
I’m a snow blower novice so others might need to help there.
thanks, believe i’m getting as clearer idea of how this thing works with multiple modules. i’ve had the snow blower attached previously and have restored those maps. will see in the spring if the lawn maps and settings restore when i reattach the mower module.
maybe you can help with another annoyance i’m seeing. when i go to previous maps, i see it is constantly autosaving maps. is there a way to turn off autosave for maps?
