Mower attached itself to the snowblower module in the app
i changed over to the mower module and when i opened the app the mower attached itself to the snowblower module in the app. the mower module says no yarbo module. the mower now wants to mow my sidewalks and driveway. how do i get the mower to attach itself to the right module in the app so it will mow the lawn areas?
Did you power Yarbo down before you swapped modules? Sometimes unexpected things happen when the modules are got swapped.
My first diagnostic step would be to power Yarbo down, unplug the battery for a couple of minutes, then start it back up and see what happens.
Let us know the results. Odds are, it’s not a big deal. (Fingers crossed)
I’d also disconnect the module connector cable and reconnect it. Listen for a solid click. Then plug the battery back in and power up.
Thanks for reaching out. Could you please try the steps suggested by rgloverii and Bryan first? These checks may help resolve the module recognition issue.
If the issue still persists after trying those steps, please go ahead and submit a support ticket with detailed information, including the troubleshooting steps you’ve already taken. This will help our team investigate more efficiently and get you back up and running as soon as possible.
Appreciate your patience, and feel free to keep us updated!
