No, I don’t have the tow bar on but thanks for that insightful suggestion.
Right from Yarbo themselves in a support ticket: “Obstacle Notice
Obstacle avoidance is still under development for Yarbo Blower. Currently, Yarbo Blower can only stop when detecting pedestrians or animals, but it is unable to bypass them. If there are any obstacles in your yard, please create No-Go Zones on the map to prevent potential collisions or operational issues.”.
Then you can take a peak right in the App itself under Reverse Blowing (Beta): Caution obstacle detection is not effective in Reverse Blowing. Clear the area behind the robot before activating.
Cut all my trees down then?
It will smash into anything in reverse. How many videos are on this and other sources showing it climbing trees, mailbox posts or you pick?
I understand you want to be the top contributor here but what you provide is not always accurate. In Overheated Battery didn’t start charging below 45 - Support & Solutions - Yarbo Forum you said what I was experiencing was a known bug, but Yarbo has adamantly insisted it is not and your statement is not correct.
Go out and try to actually use this thing with the leaf blower! How do you go from “Full disclaimer, unboxed but never connected mine yet.” to defend the leaf blowers honor. The most naive statement is quoting a release note and since its in that it must be true. If the release notes had any accuracy the volume of outraged customers would not exist.
So, go put it on and send it out to your yard even if it doesn’t have a single leaf. Works like the marketing videos? Works even within 10% of an acceptable condition?
