Just an FYI I received this same message around the middle of May, so it is not fixed yet.
Then it may not be related to the DC version. If you continue to experience this issue, please submit a support ticket so our team can further investigate and assist you.
Saw it one time and it hasn’t reoccurred. Odd one.
I have noticed a periodic drift. It makes me think one of the satellites is not where their table thinks it is. if I catch it I shut the mower down and wait for the position to look normal again. The biggest pain is when it is sitting on the charger and will not charge because it thinks it is 10 feet away
Hey,
If this is a known issue, then why would you put extra load on support (and to the customer to collect logs and endlessly discuss with AI) to look at more and more similar tickets where the issue is identified and promised to be fixed with next update?
I agree Yarbo Support struggles with quickly identifying known issues.
From my professional experience in Services, it is usually a tool/system/time issue (or lack thereof) than a “bad employee” issue. Most employees try to do a good job, but when they lack good tools, training, and/or reasonable work time, they struggle. That struggle often appears in the form of elongated ping-pong communications with customers.
Agree. So basically if there is a ticket for yarbo crossing NGZs, yarbo missing to mow stripes, yarbo getting out of boundaries by 1.5m .. support should have enough info to pass to developers to fix the issue and all further tickets should be dismissed, unless they are really struggling to find what causes the issue. But in those rare cases me, as a customer, would appreciate that I can reproduce the issue and logs are collected without silly AI advices to change the setting and try this and that before the work plan.
@andris.leja @GROWF Hi there, I’ve gone through the relevant ticket once more, and it appears that this case may not be the same as the known issue we previously identified.
We apologize for the earlier miscommunication in the ticket. I’ve asked the FSE responsible for this case to escalate it to our R&D team for further investigation so we can better determine the root cause.
Thank you for raising this concern. We also understand the importance of distinguishing known issues from cases that still require further investigation, so users are not asked to repeat unnecessary troubleshooting.
Thank you for the update.
FYI I have mowed once since opening the ticket. I mowed on Friday, Aug 14 without experiencing the issue. I turned on PPVS which might have helped mitigate the issue.
My next scheduled mowing is tomorrow (Tuesday, Aug 18) and I’ll be monitoring for another occurrence. If it again mows without this problem I might try the following mowing (likely Thursday, Aug 20) with PPVS turned off. Trying to get data points the engineers can use.
That is how I got rid of this same error, I had to turn on PPVS but I turned the settings down just a little above minimum. Odd you have to turn on a feature you don’t want, but it worked so I left it this way.
