Hi there! Sometimes this can be caused by a temporary system glitch. Could you please try starting the mowing task a few more times to see if it operates normally now?
If the issue still persists, please feel free to submit a support ticket and include any relevant information, along with a video showing the behavior. This will help our support team investigate the issue more efficiently.
Have you check to make sure there is a pathway just off the charging pad to an area to be mowed and/or checked to make sure there are pathways connecting the areas to be mowed?
@bryan.wheeler - I did try that, twice actually and no luck this time.
Yarbo Support responded to my ticket and said its “most likely a software glitch” and theyre going to remote in and fix it. I’m guessing that won’t happen until the overnight hours.
Really it should say something like “Yarbo hasn’t moved 1 meter in 10 minutes while in operation.”
The current wording is not clear. “Planning” to me means Yarbo is deciding what to do, and of course Yarbo isn’t going to be driving anywhere while recharging.
Yarbo may be stuck error means nothing to Yarbo techs, when I called in that I got that message when my Yarbo died, he admitted that error did not tell them anything useful, many things can cause it. My unit sent that message like 5 times in a row before it died, and it did not help the tech one bit on diagnosing what happened.
Ya and its frustrating dealing with tech support. They responded asking for more info this morning, and I responded within 5 minutes… no followup after that though and experience tells me they wont respond until early tomorrow morning.
Gotta say, not really impressed with tech support today. This is the response I got from Nick. I’ve already sent screenshots of the diagnose results, recorded an issue log, and given them the green light to remote in.
My response to Nick was, “if you can’t diagnose it then send a new Core”.
Dear Customer,
Thank you very much for your patience and your response.
We sincerely apologize for the inconvenience caused.
Without a recorded video or screen recording, our ability to perform further remote diagnostics is quite limited. After completing all available troubleshooting steps at this stage, we recommend that you try starting a new task again in an open and unobstructed area.
During the test, please observe whether the GPS signal and other network connections of Yarbo are stable and functioning properly. If the issue still occurs when starting tasks in other areas, please let us know again.
Thank you very much for your cooperation and effort. We truly appreciate your support.
I would start a task and let it sit there and then try calling them to diagnose it while it’s in that state. If you can’t get through, screen record the app and video the Yarbo and its surroundings. That should give them all the evidence they need to perform further diagnosis.
