Yarbo lost GPS position. Solved
Hi all,
Yarbo was really doing well but now suddenly it lost his GPS position. It thinks it is on the charging pad, but it is not. See images. Screenshot from the app is where Yarbo thinks it is. The picture where it actually is.
Also, I cannot start mowing because the position is off. I got the error WP006.
I did restart the system and also unplugged the battery. Any idea what I can do?
I tried to search if this was covered but I cannot find this in the forum.
Thank you
Could reinstalling the Docking Station help?
How’s the Data Center’s mount? Stable? Any movement?
How long has the rover been like this? Usually when I see oddball GPS issues, I don’t do anything, just wait. They typically clear up.
Was it in the middle of a Work Plan when this happened, or did it roll out there on its own – we did have that problem long ago, so make sure your rover firmware (usually automatic), App (you have to update it), and Data Center firmware are all up to date (you check it and update it in the App).
Hi Ken,
The Data Center is stable. I secured it so it cannot move.
Just overnight. Yesterday it was still working perfect.
It happened while it was on the charging dock.
Everything including the data center is up to date.
Ok, I will wait and see what happens.
Thanks
Yay! Found the solution.
I reinstalled a previous map and the issue was fixed.
Seems like the map got off in a way and with reinstalling the map Yarbo found the charging station and is back on track!
