Yarbo ran away during power outage
I had a power and internet outage at my house the other night. About an hour into the outage, Yarbo activated and started driving off without any command. Luckily I noticed quick enough to run outside and hit the E-stop before it caused any damage or got too far.
Well that is not such a great thing. Was there any schedule item that might have sent it out?
No. There were no active or scheduled work plans.
Hi there, I’m really sorry to hear about this issue. This will require further investigation by our team. Could you please submit a support ticket and include the approximate time when this happened? This will help our team retrieve the relevant logs and investigate the root cause. Thank you for bringing this to our attention!
I wonder if it was that odd “auto dock” function. If the dock loses power and Yarbo can’t find it, does it go looking for it?
All the more reason this shouldn’t be a feature and if it’s needed it should be able to be disabled. They really need to fix docking so that it checks for GPS location AND a Bluetooth signal when it docks. No signal, no dock.
Agree.
I parked the Yarbo in an “Undefined” area to avoid charging it since it was not in use. The map drifted and Yarbo thought it was in a position it wasn’t, tried to auto dock to charge and started running into things.
Not good.
Oddly enough, mine has stopped doing that the day after my last post about it.
Hat-tip to support for fixing it, but a notification would have been nice so that I could stop having to mitigate that behavior.
Interesting…
Hi there, sorry for the inconvenience caused. Currently, when the system detects that Yarbo is within 1 meter of the docking station, it will automatically attempt to return to the dock.
I understand your concerns about this behavior, and I’ve noted your feedback. I’ll pass it along to our product team for further evaluation.
