Yarbo erratic behavior on power outage
Just now there is unplanned power outage in my property.
An hour or so before that Yarbo has finished the work plan and was nicely sitting on the dock and charging …
And then suddenly it started to panic. Threw an error message about failed charging and started to drive about the dock and try to park on dock again … so I manually ended it’s suffer and drove manually back on the dock. And let it sit there and wait till electricity will be back. After some little time I again get the failed to charge error and when checking the smart vision, Yarbo is again off the dock. Why the hell it keeps overthinking something what it should not think about?
Well that’s a new one. Wonder if that’s a new feature? It obviously will not work if the dock doesn’t have power. They really need to listen for the wireless signal from the dock before trying to dock.
Hmm. This is new to me as well.
Guess it’s fairly straightforward to try and reproduce. I’ll power down my dock while Yarbo is on it and see what happens.
In my case Yarbo was actively charging after finishing the work plan (had around 60-70% battery level at that moment).
Power outage affected both - docking station and data center. Both lost power.
From one hand i would understand the idea when yarbo tries to recover from ‘failed to charg’ error by just re-docking, but with switched off data center that might not always be successful move and most probably there is no automatic fallback to net-rtk feature implemented.
The current behavior is that if Yarbo is unable to recharge successfully, it will automatically try up to three times. If all three attempts fail, the system will then notify the user.
At the moment, Yarbo cannot distinguish whether a charging failure is specifically caused by a power outage. That said, I’ve shared your case and feedback with our team so they can review this scenario further and consider possible improvements.
It definitely should handle power failures more gracefully.
I agree. Yarbo should know that it was successfully charging on the dock, and if there is no position change, nor any track motor activity and charging stops, that would indicate power outage and no retries are needed.
I believe the dock has some BT functionality. It should know when that signal disappears.
To clarify, if Yarbo is actively charging (successfully) and power is lost, it will try again 3 times to recharge? This is not good. It needs to verify the dock signal is there before it does it if so. It should also do this anytime it is docking autonomously.
Yes, that is the current logic. We’re aware that there are some limitations with how this is handled, and I’ve passed your feedback and suggestions along to our team for further review.
