I completely understand your frustration, especially when you’re eager to use a brand-new machine and it won’t even acquire a GPS lock.
I’ve checked your support ticket (#204874). We are currently working through a backlog of support tickets, which has unfortunately resulted in slower response times than usual.
That said, I’ve already asked our team to review your case as soon as possible. We understand that your Yarbo is currently unusable, and we want to get to the root cause of the issue as quickly as we can.
We sincerely apologize for the inconvenience and appreciate your patience while our team investigates this further.
Here is the email response I got. Hopefully at some point today the mower will just start mowing on its own
I have personally checked with our engineers, and they confirmed that the issue you are experiencing (the Core not connecting to GPS) is caused by a firmware problem. They have already taken action, and a firmware update will be pushed to your Yarbo within 24 hours. Once the update is applied, your GPS should start working normally.
That was an errant “Solution” press on my part, it has not been fixed yet.
That being said Yarbo came back and said there’s a firmware update I need that they’ll push out in the next 24 hours. Apparently there’s firmware that we can’t update by the app.
Same issue here. Looking at the diagnostics page everything looks good except connection quality is consistently 0.00. Tried reinstalling/reinitializing positioning service and using both Data Center and NetRTK.
Get a ticket opened and post this thread in there for reference. I will say that your DC levels are a little low. Ideally you want over 40. Is your DC out in the wide open with 120 degree clear and unobstructed view of the sky? Perfect time to move it if not.
I hadn’t considered that. In that case there should be a page that displays all the various firmware and revision levels. If they told me that they need to update firmware for X component I would want to be able check that it was actually updated. Not critical but would be nice.
Having the same issue, my core is consistently seeing 0 satellites even after several reboots. Has been working perfectly before this, suspect a firmware issue
Zero satellites I think is a different issue. Still possibly firmware related but a few have been RTK antennas that have gone bad. What does your DC scatterplot look like? Tap the yellow details under RTK in diagnostics.
What are your CNR values out of curiosity? Do you see any satellites on L2 or total satellites? Or both are blank? Mind posting your diagnostics and scatterplot?
