App claim I have no network
Good evening,
since several hours, the Yarbo App claim, I have no network snd should verify my Router.
However, I have a WORKING Internet 5G access eith 50MBit and my whole farm is working.
For the 802.11ab I have even 8 outdoor repeater working, covering 12ha without any problems.
Why can the App/Datacenter/Core not get a WiFi connection?
All signals are excrptionel strong.
I have switched the Core to use Wifi instead of the Datacenter connection, but after some hours (working or not) it is reset.
I strongly suggest to the Yarbo Software Developers, to force connections to DataCenter AND WiFi and whatever has the better coverage and signsl strenght.
Thankyou
Order of priority for network connection is HaLow, WiFi, Cellular. Yarbo will auto failover to whichever has the strongest signal in the order. HOWEVER, WiFi on the rover has been known to cause HaLow disconnect issues, so I don’t recommend using it. Try forgetting your WiFi network on the rover (make sure HaLow shows good signal and status TRUE in your diagnostics before turning it off). See if that helps any. If you continue to have issues, some screenshots of your diagnostics could be helpful.
As Bryan mentioned, Yarbo will automatically switch between the available connection methods based on connectivity.
Could you please share a few screenshots of the Diagnostics page when the issue occurs? That will help us better understand what’s happening and assist you further.
