Battery voltage fluctuates
Just got a ne Yarbo, charged it 100% and started to make the map. It immediately shut off and doesn’t turn on again…
If I try to charge on the charging station, nothing happens.. if I try with the manual (wired) charging it shows me a red status light.
The battery jumps between 30&33V
What can I try? Any ideas?
Solid red on wired charger means it’s charging. Solid green means it is fully charged. The rover has to be powered up for wireless charging to work. Try charging the battery to full and see if it fires up after. If you hear ready to work but still can’t connect try unplugging your DC for 5 mins and connecting it back to power.
It’s a 10S NCM chemistry (Nickel, Cobalt, Manganese) Lithium Ion battery pack, so nominal voltage is around 36V (Yarbo specs) and fully charged is 42VDC. At 30.5V (Your leads are reversed) the battery is dead. There is a more complete discussion of battery life and voltages at Battery charge limit
Tim
I’m sorry to hear about the issue. It may be related to a battery problem, and our support team will investigate it further through your support ticket. We truly appreciate your patience and understanding as we work to resolve this.
