bigger pins/screws for the plow attachment
hi . i have had a ball working with yarbo this winter and it has been working flawless for me. one thing that happened in the middle of a wet snow storm is i wanted to switch to the plow but I had to take the auger guard off. The screws for this are very small and the opening to screw them in is very small and tough to align . i like that you put wings on the plow replacement screw which made them okay to get in but still hard to screw in since the screws them selves are small. maybe you can note in the assembly manual to replace the screws with quick release ones before taking off the guard in a place where you can lose them ( like in the snow :slight_smile: . Thanks!
This is a good idea to update the manual to swap those screws. Perhaps they should be included with the S1 as an optional screw choice based on user preference. What I would much rather see is the plow blade with a quick attach and release type of clip system. No screws, just push it in and it locks in place. Push a couple of tabs on each side and it unclips and removes quickly.
Thank you for your suggestion! We appreciate your feedback and will pass it along to the relevant department for consideration. We’ll keep you informed if we decide to implement this change. Thanks again!
#!TeamSnowPlow
