Through my testing, it’s clear that the blower planning algorithms don’t factor in the fact that the blower discharge is on the side and any leaves directly under the Yarbo will be missed. Planning seems to be the same as mowing or snowblowing, meaning that it thinks if Yarbo goes over an area then it means it will be cleared.
Take a look at this mapped plan and the end result. The two paths down the middle are completely missed.
And the planner does not understand that the blower can easily clear more than one mower-width to the right. Can we please get up to 48" spacing in the plans too so as not to waste battery?
If you mean select a certain area of your map to only blow that area. You cannot.
Or if you mean can you select an area to have leaves blown into a pile. You cannot.
