It’s at the bottom of the diagnostics page. Should have all 4 cameras listed. If your app shows HaLow, then status 3 for DC is ok, may just be the less latent path.
That indicates a communication drop out. Usually the app to core. I’ve seen this too on SmartVision. I don’t think it is a problem with your DC (necessarily). Usually you can back out and tap the broken chain to reconnect.
Cameras look fine from an operational state. Something else weird going on with your core to server comms.
If you’re still experiencing this issue, please feel free to submit a support ticket. Our team will be happy to investigate it further for you.
Ticket 217342
Yarbo did some kind of remote fix. Cameras are working, but slow to load. No idea what was done.
Do the cameras still show the same firmware versions?
Interesting. So it seems most of them needed a firmware update.
But the FC camera still has the same firmware version it had before. I’d love to know what Yarbo is doing behind the scenes to fix these things. We should be able to diagnose and correct things ourselves without being reliant on the “FSE” doing it for us.
It will adjust the image quality based on signal strength and available bandwidth. I notice mine is crystal clear when it’s close to the data center vs when it’s farther away and signal strength is on the edge of usable.
Generally speaking, I’ve also noticed that my front camera is more pixelated than the other cameras.
But to Bryan’s point, I’ve also seen variations in image quality, likely due to how far away Yarbo is from the DC.
Mine are normally very clear, but I get the pink hue syndrome quite a bit.
I’m experiencing the laggy camera issue today. It’s never lagged this bad, usually only 5 seconds or less. Right now it might load and show after a minute and it might just be one camera or just two. Different every time I try to connect. I wonder if it has anything to do with updates. I’ll try restarting when he’s done with his job today.
What is interesting in your screenshot is the back camera had a state of disabled. You might have a camera issue that could be impacting the others. Front camera was in an unknown MAC state too. I’d pull power cable to the battery for 5 mins, then see if they work better. If not, submit those screenshots to support to check them out.
Please keep us updated if you continue experiencing this issue. If the problem persists, feel free to submit a support ticket so our team can further investigate and provide assistance.
Thank you for your cooperation.
