I opened my new Y series core yesterday and attached the Smart Module. Very excited to get things going. I have a problem though in that none of the cameras seem to work. When I go to the Smart Vision section in the app, or even the Follow Me, the cameras show no signal. I’ve got a ticket open with Yarbo as I called their support and went through a few things, but thought I would reach out to the community to ask for advice.
My initial thought is to let your Yarbo install any firmware updates that are needed.
If the firmware is already updated, give Yarbo a reboot and see if that clears the camera problem. My cameras do this on rare occasions, and a reboot always gets them back.
Hi, thanks for the reply. I did install the updates and rebooted but does not seem to have disappeared. I am hopeful that Yarbo technical support will fix it without needing to send me another unit. They asked me for a shipping address at stage one which worried me slightly that they are not confident they can fix…
Sorry to hear it. Certainly not an ideal first impression of Yarbo.
In the interim, you should be able to use the robot and start familiarizing yourself with mapping and learning the ins and outs of how it mows the lawn.
Up until late last summer, live camera views weren’t even available, so I wouldn’t say you can’t use Yarbo without them. Take this time to start learning how the robot works, and we’ll be here to help you along the way. And hopefully Yarbo Support will get your camera running shortly.
There are a few Lymow owners here on the forum. I never bought one myself, but have been following them closely since day one. I think they have the potential for a great product if they keep iterating and learning from their mistakes.
Candidly, these are early days for all of this current generation of robot mowers. So lots of innovation, lot of trial and error, and occasionally frustration.
Hi Martyn - just want to confirm you are on 3.13.11 firmware and using app 3.18.6? If so, unplug the DC POE injector and battery cable for 5 mins and plug it back in (starting first with the DC). If they still are not working, make sure your HaLow connection is TRUE in diagnostics and your core is not tethered to your home WiFi.
Hi Bryan, thanks for your reply. I am on 3.18.6 of the app and 3.13.11 of the firmware, both marked latest.
I will try unplugging the DC POE injector and battery for 5 mins then plug back in. My HaLow is true but I am connected to WiFi on the rover so I will disconnect that. Would it be normal that I am not connected to WiFi to make the cameras work? I will let you know how I get on. Thank you for your pointers!
Glad to hear it. They should work on WiFi, but stranger things. WiFi generally isn’t recommended for daily use though. It can cause weird convection issues.
interesting… I’m not having the exact same problem, but I am having an issue with only my front camera showing only a dark gray screen, yet I’m not getting any errors while the rover is operating.
Not sure where to find camera diagnostics in the app. Haven’t disconnected the battery as this is becoming far too routine for troubleshooting. Seems ridiculous to have to disconnect the battery all the time.
Also appears the DC is malfunctioning again. Seems to be running in local mode since connection is stuck on 3.
