So my driveway is a bit of a pain to get mapped correctly with the snowblower module due to some retaining walls and the location of my garage. I would like to use a few sidewalks in front of my garage door and also put a docking station in front of my garage and when I’ve tried to get the core to go recharge it tells me that it can’t which I assume is because it would have to drive over the sidewalks to get to the dock. Can the sidewalks be toggled on and off just like the ngz can? That way yarbo can drive over that area with the sidewalks being there
Sidewalks can be added to work plans. You can create one with them and one without. You need a pathway from the dock to the area. It should ignore the sidewalks if they aren’t actively being worked in the work plan. Make sure you run the plan a few times and that the sidewalks don’t overlap too much. Sometimes that may cause it to run it in reverse sometimes.
Hi there! As Bryan mentioned, sidewalks can’t currently be toggled on and off, but you can choose whether to include them in a work plan by adding or removing them.
The issue with returning to the dock shouldn’t be related to the sidewalks you’ve mapped. As Bryan suggested, please check whether there’s a pathway connecting your docking station to the work area.
If you’re still having trouble, feel free to share a screenshot of your map with us. We’d be happy to take a closer look and offer more specific suggestions!
You are right that if the Autonomous Work-Plan ends near an end of a Sidewalk the Core may not return to charge, it throws an error message.
Issue being the Sidewalk being right there where it stopped causes confusion.
And No, Sidewalks don’t have an “on/off” like a NGZ.
So- I’d write this up and submit it to Yarbo, sort of a bug? I don’t know of a workaround for this, and ensuring your Work-Plan doesn’t end near the Sidewalk isn’t practical.
HEY! What if you redid the sidewalk(s) so one end was further away from the edges, more into the driveway? The other end might still be near the Perimeter, but it may solve half of the issue?
For some reason yarbo refuses to fix these issues with sidewalks, dead end, and memory paths. I just don’t understand why. I really tried hard with the memory path reverse, but they just ignored that it happened.
They’re on it right after NGZ violations. Just hold your breath it’ll be here any minute.
Reverse issues started way before ngz issues. You wait your turn bud.
