I only use my yarbo for snowblowing my driveway and I think using a few sidewalks inside ofy driveway will help with a few spots along the parameters. If I add some sidewalks let’s say near the edge or even a few feet inward from the edge with the core snowblow there driveway in that area just like the sidewalk is not there? I would like to run the sidewalks first and then have the core clear the entire driveway like the sidewalks were not there if that makes more sense?
Be careful with “Sidewalks” the don’t preform very well. Tend to run a lot in reverse. If you have rocks around your driveways or sidewalks be very very very very careful.
Agree with Ben. Definitely test it a few times before you actually need to use it. And to answer your question, it will ignore the sidewalks when it is running the area plan. Your plan should work as long as you don’t hit a bug where they run backwards.
Yup the backwards warning extends to dead ends and memory paths also. Use with caution!
Tag for the PPP China Team. It’s only been 2-years.
Don’t rush the dev team.
