Connection stability while re-mapping my yard.
I have been trying to remap a couple of my yard areas with no success due to what appears to be just minor tree cover. I recently installed new Yarbo RTK Pro antennas on my core and they have been functioning really well while mowing, but for some reason when I try to map my connection fails with the least little bit of tree cover or other interference. Does anyone have any suggestions for this issue? This is the first time I’ve had any serious problems with mapping.
When you say the connection fails, is there an error message? A lot of the times this is bluetooth or WiFi connection issue related. If you have good cellular signal in your yard, try disabling bluetooth and wifi on your phone and see if that helps. If you still have errors, please post some screenshots and we will see if we can help.
Could you please share a screenshot of the error message you’re seeing? That will help us better understand what’s happening and look into the issue more accurately.
You can crank up the PPVS setting temporarily while mapping to allow the yarbo to keep mapping through those temporary GPS drops.
I feel you. I have trees all over my yard. Surprised the yarbo works so well considering I haven’t received my Pro antennas yet.
