Mower blade replacement
Hi, just a thought regarding blade replacement - if you add a hole to the cutting discs, as well as in the deck above, one could safely lock the disc while working underneath by just inserting a screwdriver or nail or whatever into the 2 holes. A template to add the holes for existing products would also help. Could be risky to blindly drill a hole in the deck from the underside without engineering guidance.
Thanks for sharing your idea—it’s a thoughtful approach to making blade replacement safer. We understand your concern and will pass your suggestion along to our development team for consideration.
One of the PPP suggested this too, Bill Dutcher a while back. It’s a great idea. Alternatively, some type of disc clamp or three pronged tool that inserts into holes on the disc so that you could hold it in place while you torque on the screws.
Could add a timer to the app that keeps track of how many mowing hours you have on a set of blades. Then pops up a recommendation when it’s time to change them, and lets you ack the replacement to reset the timer.
Like an hour-meter on your gas mower that tells you when to perform various service operations. Great Idea. Probably could keep track of the total hours or track rotations, and any other moving parts that need regular service intervals. That would be very useful. My car does that.
