Data Center Mount Hole Pattern
Good morning,
Does anyone happen to know what the hole pattern is on the Data Center Mount?
Not off hand, but it would be good information for Yarbo to document here. Yarbo Core & Module Dimensions & Specifications | Yarbo Wiki
Mount itself is 4.75 inch diameter.
Three, .25 inch mounting holes on a 3.5” diameter.
Holes ARE NOT on a common orientation (90, 45 degree) to vertical.
Will not fit on a standard 2x4. At least one hole will be too close to an edge.
The included screws are a fine thread. I added a 2x6 inside the sheathing and used standard lag screws.
Cable exit (if you don’t pass the cable through the wall) is about 20 degrees off the top.
