Is there a way to have a shorter mounting rod for the data center.
Hi everyone yarbo owner, has some of you found a way to find or to modify the mounting rods in order to have shorter house clearance when mounting the data center on your roof side in a 90 degrees pattern?
Thanks
I know quite a few people who just cut the rods and drilled a new screw hole. There is also some 3D printed mounts for mounting without the pole out in one of the 3d print sites.
I use a 3D mount as the stock mount wobbles too much
What about angle grinder? :grin:
I designed my mount and printed it in PA12-CF, works great
