I have a 2024 model (2023 upgrade). I saw a YouTube video that had the 2 gen 2024 (25 model?) and it had a separating wall behind the module so you couldn’t see all the electronics.
Is this something that I can add?
Yes, put a ticket in with support and they can assist you.
Can you share the video link, I thought all the components you will be able to see. If I remove front attachment, I will be able to see all the electronics chips, etc.. in my rover, even though it appears to be weather sealed by epoxy gel, I always worry small twig will get in there and when attachment raises it will disconnect something.
They added a cover in the later models. If you ask support they will send you one.
See these threads
There is a point where he compares the two
I installed the panels today. I would post a picture, but I can’t I figure out how on this forum.
Installation instructions are at the link below. They really should’ve shared that with you in your ticket. @Yarbo-Forum
So that’s pretty much what I did without the instructions. However, I didn’t have the slot at the top that’s shown in the video. I had to loosen the top (2 bolts by the side cameras and 4 bolts in the battery compartment) to slip the cover underneath
Interesting, it still should’ve went in even without the slot. But, at least you got it installed!
It did, but it wasn’t fitting without loosening it. It’s pretty brittle plastic and it would have cracked if I forced it.
