Does elevation of the Data Center in reference to where Yarbo is working make a difference
Trying to setup the Data Center. I have a shop at the bottom of the property, but the elevation is 30-50 feet lower than where Yarbo will be working by the house. Will this be an issue? The Data Center is flashing red no matter what I do, it does have a clear view of the sky.
HaLow cannot penetrate earth, but Cellular or WiFi could pick up the loss of any HaLow signal. I’d suggest trying it and seeing how your HaLow signal works. Might be just fine. Try not to connect to your home WiFi if possible, it can cause issues. Especially if switching back and forth a lot between HaLow and Wifi.
For your red flashing DC, go into settings and “Reinstall Data Center”. This should fix that issue.
