I had a problem with Yarbo not being able to align itself to the docking station. As a result, I decided to uninstall and reinstall the docking station. At the step in the instructions where you save the position of Yarbo, I back Yarbo up until the “Save” button lights. Then I move Yarbo about 5” more and the “Save” button goes out. At this point Yarbo is about 15” from the top of the charger. If I back the Yarbo any more, the button stays out. I have manually deleted all paths going to the docking station as well as did a power reset. The docking station has not moved from it’s original position as this is a reinstall. Why is the button going out when I back it up any more than in the picture? I am stuck at this point.
Park your core on the dock. Make sure that each track is between the yellow lines on each side and the metal bumper in back is lined up with the yellow line on the back of the dock. On the main app screen with the picture of your Yarbo, press the battery icon to start charging. Once it starts, go into your yard, edit map, docking stations, and delete any docking stations you see. There may be several. Then exit out of edit, go into settings and reinstall the docking station. Don’t drive it off, just keep hitting next and finally here it is. See if that works for you.
