Light on docking station no longer works and Yarbo not docking itself
a couple of days ago the light on my docking station quit working. It is still charging the Yarbo, but not showing the green or blue light. in addition, my Yarbo has failed to align itself correctly on the docking station once this started. it gets close, but ultimately drive on and off the pad before finally failing. I have had to manually dock it the last several runs. Any thoughts?
Open a ticket. Sounds like your dock may be failing.
My system just started doing this 2 days ago (EXACTLY THE SAME as you explain, no lights, still charges, issues aligning). I just opened a ticket.
Did your issue get resolved?
I had the same issue a few weeks ago. The entire dock was dead and had to be replaced. Have you checked with a multimeter to be sure power is making it all the way to the connector? If you’ve got proper voltage at the connector but no light that most likely means it’s done.
