Front camera is foggy
okay give me a minute to do that
okay pull up the mounts verified connections are tight swapped side to side drove it around no change unable to find GPS
Still low L2 satellites? If so, sounds like something else like maybe a bad RTK cable or something.
okay now it grabbed a GPS signal so I sent it out to do its job see how far it gets
what do you consider a low L2?
Anything less than 10 is really low. It can work this low, but ideally it should be 10 or more.
And it lost the signal yet again I don’t think I have ever seen it that high so this new Firmware to make it picky about GPS signal has effectively made it useless on my Property
I noticed PPVS is disabled. I assume you did that intentionally for some particular reason? It would possibly help it stop less frequently if enabled.
well it did not seem to make any difference when it was enabled so I just left it off
and now on flat ground it thinks the module has been lifted
Yeah they turned rollover and lift detection on by default in this firmware. You can disable those in working preferences. They are a little sensitive. If there is a hole or something and one of the caster wheels drops down into it while the deck remains suspended above, it triggers the lift sensor.
I went out and smacked the module and it cleared the error
Okay disabled that crap
all this because I wanted to check to see if the charging issue was resolved only to find out more issues are present :zany_face:
I’ve checked our system and found your support ticket regarding the foggy camera. It has been escalated to our field service engineer for further investigation, and we’ll make sure to help get this resolved.
As for the GPS issue you mentioned, could you please add it to your existing support ticket along with the troubleshooting steps you’ve already tried? This will help our support team assist you more effectively.
We understand this may be frustrating, and we truly appreciate your patience and understanding as we work to resolve these issues for you.
First mowing of the season and fog in the front Camera on my mower pro. Even if you turn off vision detection yarbo keeps seeing an obstacle on the pathway to the mowing zone.
Can you place it in the sun to hopefully dry out? I’d get a ticket in. It shouldn’t get fog inside.
tried opening a ticket on the support center on the app but still didn’t work so sent an email. yes will try drying it in the sun. no it shouldn’t.
no fog has come into my M1
Ticket number 181781
Hi there, sorry to hear about the issue—this is not expected behavior.
Your case has been escalated to our Field Service Engineer team for further investigation. We’ll work to identify the root cause and get this resolved for you as soon as possible. Thank you for your patience.
