Front module problems!
Last week my blower stopped working. Since then, I have been debugging non-stop to figure out what could be wrong and I am at my wits end.
  • I’ve rebooted a dozen times (through the app, holding power button down)
  • I’ve disconnected the battery a dozen times, waited as long as 12 hours, reconnected.
  • I’ve checked firmware versions.
  • I’ve swapped the vision module and blower module. (I do have the Mower Pro module but it’s still new in box as I just received it and have not had a need to open it yet).
The main issues are:
  • All functions of either attached module are completely unresponsive. No lights. No cameras. No auger movement. No chute movement. Nada.
  • The module LIFT itself is unresponsive – it is stuck at the highest setting (+2in) and will not respond to the app or physical controller buttons to move it up or down.
Any thoughts? Your feedback is much appreciated.
It sounds like you have something going on with the core. I think you need support to diagnose this. You’ve done what I would’ve suggested at this point. Do you have an open ticket? Drop the ticket number here so the forum admin can follow up on it for you.
I’m really sorry to hear about the issues you’re experiencing. I’ve checked your support ticket in our system, and we truly appreciate your patience and cooperation throughout the troubleshooting process so far.
Our support team is now investigating this case in more detail to determine the root cause of the problem. They will follow up with you as soon as possible with next steps or a solution. Thank you again for your understanding and for the thorough troubleshooting you’ve already done—it’s very helpful to our team.
Thanks Bryan – yep I am a very technically inclined person and I read what others were doing first and tried to fix it myself… hopefully support can help. I think they found my ticket already but for the sake of helping myself, this is the number: #146778
Sorry to hear of your malfunctioning Yarbo.
As @bryan.wheeler said, you really have already done a methodical job in trying to resolve the issue. You did everything I would have done!
Hopefully @Yarbo-Forum will be able to escalate your ticket and get you to a swift resolution.
