Blades stopped moving from 4", then stopped spinning all together, now I have a power board issue warning… and this is a replacement already… help
Try another module and see if the power board issue persists. You can hold the power button for 60 seconds to reset the error. If it comes back, get a ticket in.
Hi there, please first try the suggestion Bryan provided above and see if that helps resolve the issue.
If the problem still persists after trying those steps, please submit a support ticket. Our support team will further investigate the issue and help you work toward a solution as soon as possible.
Unable to make ticket. Every time, it says unable to send ticket. This is a replacement module already. The original one was giving the same code.. very frustrating. Attempted reset many times.
Email support directly and it will show up in the app after. Support@yarbo.com
Hi there, you can directly contact us at support@yarbo.com and our team will be happy to assist you.
