Ghost objects
Another question. Starting the mowing season. The obstacle detection seems to be very sensitive. Yarbo pro senses ghost objected which may just be taller tufts of unmowed grass. Is there a way to delete the obstacle or override ?
If you have taller grass for that initial mow you can go with “gentle contact” instead of moderate bypass. Gentle contact is bumper only, so make sure you have NGZ’s around anything you don’t want it to run into for avoidance to be activated. Once you have the grass at a good height, then you can switch back to vision.
