Halow and Gps not working
Got a new Yarbo, but it doesn’t seem to get a good GPS lock or halo. Moves RTK all over, checked satellites, checked all antennas on the unit and RTK, and all checked out. Reset the RTK and core more times than I can count and got the same thing. The core won’t even connect unless it’s working through Bluetooth. Network signal is green on RTK, and I have the core parked directly under it with nothing. I’m lost!
Everything looks good, but your data latency is too high for RTCM to work. Did you take that screenshot after the DC survey mode? I would try a reinstall of the DC and see if that corrects your issue. Settings, Data Center Reinstall. Your firmware is also out of date, so it won’t work until that updates. If you can’t get it to update after the DC reinstall, connect your core to your home WiFi temporarily and let it firmware update. 3.11.7 is the latest. It should start after about 30-60 mins once it has internet.
The core won’t even hold the wifi, just immediately jumps to bluetooth. I have a unifi home system with access points in and out. Have a mammotion luba and no issues. Have wi fi cameras around the house with no issues either.
If you are in bluetooth range, it automatically switches to bluetooth. The firmware is also too old for it to connect to Yarbo’s servers (except for firmware updates). Hence why only BT works. Once it firmware updates, it should be able to connect over HaLow to the internet.
Yeah, that’s what I want to do and wish there was a way to push the update. That was taken after I moved the rtk for the 6th time. Acts the same everywhere I put it. Get good stats but the system won’t hold the wi-fi. Its just right outside a garage that i have an access point in.
If your home WiFi won’t stay connected, Toggle on cellular. That may help force it to update over cell.
I’ve tried both a 5ghz and 2.4 ghz band
Got cellular on as well.
Do you have a ticket open yet? If not, I would recommend opening one and you can post the ticket number here. The forum administrator will follow up with support on it for you.
Ticket 134768
@Yarbo-Forum See the previous post.
I actually think its now good. Seem to completely come to life over the 24 hrs I let it sit outside. I think they must have pushed a firmware update. Thanks for the help!
Awesome! Check the settings, version information and see if it is 3.11.7 for the firmware. If so, you are all set! Complete the map setup and docking station install process. Also make sure you update your DC firmware if you haven’t already.
Hi there! I’ve checked the backend data and it shows your unit has already been updated to the latest firmware version 3.11.7. If you have any other questions or need further assistance, please feel free to reach out.
