HaLow Antenna for Rover
Needing the male threaded portion with the threads that comes up to HaLow Antenna for Rover. Seems when GPS is lost and Yarbo keeps driving, you lose RTK, and HaLow Antenna for Rover. luck the weak RTK is cheap plastic and just broke clean off. But HaLow Antenna for Rover, was stronger I guess snapped the whole threaded part off in the HaLow Antenna for Rover. I’m sure it has a wire going in the core because I see two screws holding it down to the core. Hopefully one day GPS will get better. This was in a NOGO zone on top of that. :expressionless_face: Seems to be one thing after the other. I did post some suggestions for RTK smooth Mushroom shaped ones, with pictures. So how long do I have to wait to get parts? Please don’t say a month???
I have had some issues what has needed spare parts sent by Yarbo. Usually from the email they promise to send it it takes 10-15 days to arrive from China to Estonia where I live. Once however it only took 5 days but then it was a case I had bought cutting discs in start of April and at the end on May suddenly realised I hadn’t heard back from them. Then they did expedited my parcel in the quickest possible way.
In your case the open a ticket with them. They will send you for sure the parts you need. To be used next time this same thing happens. Then make sure to go by your local hobbyist electronics store. Take your broken parts and as Yarbo is using luckily the most common parts the local shop will have you the parts you need straight from the shelf. I for example live in a small town of about 30 thousand people. Our local that type of store has 90% of the times had the antennas-wires I needed and if they didn’t they ordered the wire and I got it on the next day. Just have the broken parts with you and most likely you will have a quick solution to this problem.
Thank you for reaching out and sharing the details.
I’ve checked your support ticket, and our team will help arrange the replacement as soon as possible. Once the replacement process is initiated on our end, you can typically expect to receive the parts within 3–7 days.
We truly appreciate your patience and understanding!
