Halow distance limits?
Anyone know how far away a machine can go from a data center for the halow to stop working? I have a situation where I’m cutting a grass airfield that’s over a mile long so my data center would be a mile plus away from the machine wondering if it can do it. also, the area doesn’t have 4G so I can’t switch to that.
This is what AI says (See below). Regarding the distance, you’re going to need some sort of supplemental connection. If you can connect to a WiFi mesh network, this could work. Yarbo does have built in Cellular that will select the best of the 3 major providers in the US. So maybe it will work OK for you. The other option might be to mount the DC closer to where you won’t have signal so that it can provide that and on the other side you could have cellular or wifi.
The Yarbo Data Center provides coverage over two distinct wireless signals:
  • Wi-Fi HaLow (Data Communication): Has an operational range of approximately 3,280 feet (1 kilometer / 0.6 miles) in line-of-sight conditions. In environments with dense obstacles like trees, buildings, or hills, the reliable range drops to roughly 650 to 1,000 feet (200 to 300 meters).
    Yarbo
  • RTK GPS Correction Signals: The theoretical satellite correction signal range extends up to 37,000 feet (7 miles / 11 km), though for positioning accuracy, Yarbo rates a single Data Center to cover properties up to 32 acres.
Key Installation Guidelines:
  • Mounting Height: Installing the Data Center high up (such as on a roof peak or gabled wall) significantly reduces terrain blockage and maximizes the 3,280-foot HaLow radius.
  • Bluetooth Range: Direct initial setup/pairing via Bluetooth from your mobile phone to the Data Center has a range of about 16 feet (5 meters).
  • Network Redundancy: If the unit travels beyond the Data Center’s HaLow range or behind heavy obstacles, it automatically failovers to home Wi-Fi or 4G Cellular data.
