Help from those experienced with a core replacement
at least it didn’t default to .8​:sweat_smile::sweat_smile::sweat_smile:
Scalp mode!
Scalp mode engaged a couple times… I dont care for that mode. :wink:
Did it avoid that grass/post length area with that jog around or did you map it that way?
Just a little off the top.
I remember those, your cutting height failure from last year. My grass shrieked in pain when it saw them.
Avoiding an obstacle. It was when I was having mower height adjusting errors. Yarbo replaced the mower and I haven’t had the issue since. It was odd though that it only did it when avoiding an obstacle. Regardless haven’t had the issue since.
Yeah… good times. NOT!
@Murali i noticed that you responded to my post. Note that although all this fixed the main issue, but my yard is inches off. If you have no go zones then you may have to adjust. I work hard, but to do less work…hence me owning a robot mower. I have yet to actually correct the mis alignment. Expect some drift…
I am brought back to this. I want to note. The DC mount sent with the original units is long. It is like a lever and allows for much dc movement over time. Past experience tells me firmly mounting an RTK is really the best way. I need to change mine as the setup Yarbo provides results in movement.
