It has been over 6 months since I have been able to use the unit correctly. I received a new complete replacement unit, and my maps were restored from the old unit. About 5 acres of mapping and over 50/60 no go zones (threes) are completely out of place. I have not been able to get anyone from Yarbo to fix the problem. I have tried to purchase an extended warranty, but it is too late. I have asked for a refund, but it is too late. I’m stuck with a $4,000.00 investment that doesn’t work. Does anyone know how to get the Yarbo team to respond, or am I out of luck?
We can try to help but might need some more details. There is correct map drift function that could solve your issue.
As @cobradunn mentioned, it’s probably map drift that needs correction. Did you follow this guide for the replacement?
In there it links to this guide on map drift correction. Take a look at both and give it a try. I would start by parking your core on the dock manually and getting it charging. Then do a reinstall Data Center and restore your maps from the cloud again. Then when it’s restored, complete the map drift correction. See if things line up after.
Hi there, you can refer to the instructions Bryan shared to see if these steps help resolve the issue. If the problem persists after correcting the map drift, please feel free to keep us updated, and we’ll be happy to assist further. Additionally, you can submit a support ticket, and our support team will be happy to help you!
