My Newly Christian Vovage for my Lawn Mower Pro went with a very significant hitch. After Mapping the area and after creating a plan. The Lawn Mower Pro Blades are not engaging. Once I stop and use the controller and press the blades button they turn. Any ideas? Is there something on my program that I am suppose to set for the blades to enagage?
I have had it a few times before with my M1 mower. but it stopped again before yarbo could investigate it. have you tried restarting your yarbo. maybe disconnect the battery for 5 min. when yarbo knows there is a mower on then run it with it on when you start on an area plan.
@Kolbe system restart yes. Battery removal not yet. I will do that now and report back.
Would also disconnect the module cable and make sure there is no corrosion. Do this while it’s power off. Putting modules on when it’s powered leads to weird issues like this. If it happens again, check for any messages in the app like waiting for blades or something
Nevermind. She finally did it. She is mowing now. Her squeaky wheels is louder than her blades.
No solution. It was following my plan sorting and not smart sorting area. The priority area was the farthest side that I have set for her to start. Newbie mistake
Glad to see the issue has been resolved and your mower is running normally now.
Hope you have a smooth and enjoyable experience with your Lawn Mower Pro going forward!
