This is my second new Yarbo. The first one failed to charge after a few weeks and they sent me new core. After the recent firmware upgrade now the motherboard disconnected error appears and it screams out ready to work every 30 minutes.
I contacted support last week and they turned it over to a different team and still have not fixed issue.
This is the worst company for customer service I have ever experienced! Maybe they should have a USA based support team!
I received my first new Yarbo about four weeks ago, and still do not have it running. Multiple connection errors, but, I just recently got this message too, “Motherboard Disconnected”. Then told to wait for two minutes and restart. Problem for me is that I can’t restart as the Yarbo is not responsive. Same message that it’s ready to work.
A $7,000 mower should ‘just work’.
I also agree with Kevin regarding support, while they are responsive, turnaround is arduous, and if the are based outside of the USA, well, it’s noticeable.
You shouldn’t have to do this, but you can pull the battery cable to shut it down. I’d let it set with battery unplugged for a good 5 minutes and then reinstall the battery cable and restart it.
Totally agree at $7k NONE of this should be necessary.
@olddog Hi there, thank you for sharing your experience. I’m really sorry for the inconvenience this issue has caused. I’ve checked your ticket in our system, and your case has already been escalated to our R&D team for further investigation. We are working to identify the root cause and will provide a solution as soon as possible.
We truly appreciate your patience and understanding. If there are any updates, we’ll be sure to let you know right away.
@jddockery2 Hi there, this issue requires a fix on our side, and your case has already been escalated to our field service engineer. We’ve received the videos you sent, and once we confirm the root cause, we’ll proceed with the next steps. We appreciate your patience.
Plugging the Rover in directly seemed to be the fix. Even though it was on the charging platform, I think it stopped charging and was suffering a low-voltage situation. Incomplete update and boot cycles were the result. After completing the update while plugged in all is well.
This is happening to me too. Not a good experience so far. Purchased during black Friday, hoping to get it working before our first snow. Battery supply issues caused delay in getting a battery. Had the Yarbo for a couple of weeks before the battery finally arrived. Battery had 49% charge. Yarbo never updated firmware - seemed to get stuck in the “Ready to work” cycle. Battery drained to 0% even though it was on charging station. I’ve since directly plugged in the Yarbo to get the battery charged again, but it is essentially bricked at this point - I can’t connect to it, and when I do it says “Motherboard disconnected” and I am not able to control the Yarbo. Also, I don’t see how you manually install a firmware update? Mine was factory set at 3.6, and I believe the current firmware is 3.10 or 3.11. When I have been able to re-add the Yarbo, it tells me it is out of date but not to worry because it will update itself. That hasn’t happened as far as I can tell. Was wondering if a firmware update would potentially fix this. VERY frustrated.
The firmware update should automatically install. But you have to connect the core to your home Wi-Fi for it to initially do this. Motherboard disconnected may be fixed by the firmware update. It should be 3.11.7. As for the charging not working, that seems like a different issue. Were you not able to manually start charging from the main screen? You should be able to tap the battery icon when it is lined up on the charger and force it to start charging.
I can’t do anything from the main screen. I can’t connect 95% of the time. When I can connect, it says “Motherboard disconnected” and I am unable to do anything. I don’t know how to get Wifi set up - I assumed when I set it up in Diagnostic Tools in the app that perhaps that would sync it to the Yarbo, but it isn’t obvious to me if that actually worked. It is saying “Ready to work” every 10 minutes or so, so it seems to be stuck in some sort of reboot loop. I’ve tried disconnecting the battery and then reconnecting to force a power off, but that didn’t help.
We’re really sorry for the inconvenience this has caused and completely understand how frustrating this experience has been. Your case has now been escalated to our field service engineer for further investigation. Our team will look into this in detail and work to provide you with a solution as soon as possible. Thank you for your patience while we work on this.
