Mowing speed
How does Yarbo determine mowing speed? I don’t see a way to set it.
If I was building it, I’d probably look at cutting disk load and adjust speed based on that.
Any idea how its done?
The only place I ever found anything related to moving speed is under ‘Working Preference’ in the settings menu.
That’s correct. Working preferences lets you set the speed. It’s a global setting and isn’t currently an area specific setting. You can set different speeds in pathways though.
It will auto adjust its speed based on load as well.
