The Yarbo lawn mower offers flexible settings that allow you to find the ideal balance between enhancing mowing efficiency and achieving a better cutting result. Whether you’re looking to speed up the mowing process or ensure a cleaner cut, there are several key settings you can adjust to optimize your mowing plan.
Go to the main page and tap the settings icon in the top-right corner. Then, select “Work Preferences”, where you can adjust the moving speed.
In the “Work Preferences” page, you can adjust the moving speed of your Yarbo lawn mower, with five speed levels ranging from 0.3m/s to 0.65m/s:
- Slowest/Slow/Medium/Fast/Fastest:
Increasing the moving speed reduces the overall mowing time. However, it’s important to note that mowing speed can affect the cutting quality: faster speeds may reduce precision, while slower speeds typically result in a cleaner, more precise cut.
To find the area settings, simply follow these steps:
There are three turning modes available to help navigate different lawn shapes:
Smart Turn: This mode involves a precise 3-step maneuver, perfect for tight spaces. While it causes less strain on the grass, it takes more time to complete.
U-Turn: When selected, the Yarbo will make a large U-turn, reducing turning time compared to the Smart Turn, but it may be less gentle on the lawn.
Zero Turn: The most efficient turning mode, ideal for wide, open spaces. However, it may be less gentle on the lawn compared to other modes
In the Area Settings, you can adjust the overlap, which impacts mowing efficiency:
A lower overlap reduces overall working time.
However, a lower overlap increases the risk of uncut grass. We recommend experimenting with the overlap setting to find the balance that works best for your lawn.
When you enable “Mow Along No-Go Zones,” Yarbo will mow along the edges of the no-go zones. This may increase the total mowing time.
Similarly, adjusting the Perimeter Mowing Laps setting will determine how many laps Yarbo makes around the perimeter. More laps mean more time spent on the task.
Frequently Asked Questions (FAQ)
1. How fast does Yarbo mow? As mentioned in the “Moving Speed” section, you can adjust the mowing speed in the “Work Preferences” page. The mowing speed impacts the overall time and cutting quality.
2. How many acres can Yarbo mow? Yarbo can mow a maximum area of 6.2 acres.
3. How long does it take to mow 1 acre? Based on our testing, it typically takes 11-12 hours to mow 1 acre (including recharge time). Note: This is an approximate value, as different settings and lawn conditions can affect the result.
4. How many acres can you mow in an hour? Yarbo can mow around 0.14 acre per hour. Note: This is a reference value, as actual performance may vary depending on settings and lawn conditions.
5. Is it better to mow fast or slow? The answer depends on your needs. At slower speeds, the blades have more time to cut the grass, resulting in a cleaner, neater cut with smoother edges. This provides a better overall lawn appearance.
Final Thoughts
By adjusting these settings, you can tailor the Yarbo lawn mower to meet your specific needs, whether that’s speeding up the process or focusing on achieving a perfectly manicured lawn. Experiment with different combinations to find what works best for you and your yard!
