RTK Cable on the Rover Replacement
Has any body found or made a replacement for the RTK cable that is inside the rover that runs up to the RTK antenna? Mine finally broke at the gold connector and I’m dead in the water. I can’t find one on the Yarbo website.
Michael
Start a ticket, that part is often a warranty item.
You’re looking for a M-F SMA jumper/pigtail that is about 16" long.
The cable is not sold on the official website and is only available through after-sales channels. I’ve reviewed your support ticket, and your case has been escalated to the relevant team. They will arrange a replacement for you very soon. Thank you for your patience!
Thank you, I had a ticket started just wondered if anybody found an aftermarket one that might work.
I have bought 15cm long RP-SMA extension cable from AliExpress. Cost was less then 1 euro per one. I have some difficult sections on the lawn and Yarbo has managed to ruin at least 2 antennas and cables.
At your local hobbyist electronics store should also have this item. Just make sure you buy the correct ones.
Those are surprisingly easy to replace on the core unit.
Thank you!
