Did you switch to netRTK in the app? You must do that first, and I would leave the data center hooked up, as it will still talk to the rover. And you need it for video unless you have super strong wifi.
The whole reason for doing this was so that I could unplug the halo and force it to stay on 4G or WiFi all the time. I’ve got significant halo coverage issues and the lag time switching back-and-forth in those weak areas makes it very difficult to use.
I’m only planning to use the Net RTK mode when I need to go do detailed manual work or map editing in those week coverage areas.
Gotcha, just wanted to be sure you weren’t trying to use it all the time like that because your cell usage would be very high if your wifi is not very strong.
What was your HaLow signal strength where it was at? Can you connect to it outside of bluetooth range? If not, that’s your issues. It needs internet for NetRTK to work. If it didn’t have a path (HaLow, WiFi, 4G), then it won’t work and show the deviation like that.
I didn’t check. I finally gave up and plugged the DC back in and continued work.
A little later in the night it tried to drive under a fence so I manually drove it back to the charger did a map drift correction and decided to call it a night. One night of lost productivity won’t kill me, and everything is better in the morning.
I’ve been using Netrtk for sometime now and I prefer it to using the DC station only. When I switched I did keep the DC station connected because of the Internet connection. I have a large wooded lot with no grass but lots of leaves. Prior to Netrtk Yarbo would drop signal and have to wait for awhile, however since I switched its like the little engine that could.
Ah. Different scenario for me. It’s the internet connection from the DC that can’t reach all of my property, so I was trying NetRTK and unplugging the DC as a work around to force a constant connection via 4G just while doing detailed manual work at a distance.
I was just doing a test run last night and will try again during the daylight if the weather holds. The thunder is rolling right now.
OK, thank you. So my test run last night was doubly invalid.
I will rerun the test today.
I’m a bit concerned that all of the switching back-and-forth might result in me losing the hours of work that I spent yesterday reprogramming my trimmer edges. I will Think positive!
Unable to do a map correction when on NetRTK. It’s Overcast outside so maybe I need to try again on a clear day. Diagnostics show weak signal if I understand them correctly.
OK, so unless it gets better during a clear day net RTK is not gonna be an option for me. Unless of course, I would be willing to relocate my dock, but that’s not a very desirable option to me.
