My 2024 core spent all of last season mowing a large portion of a 6 acre property without issues. This season, I’m having nothing but connectivity issues and frustration. Here’s a summary of the situation. I’d love some explanation from Yarbo on this.
- Nothing about the physical install changed. DC location is the same, Dock location is the same, no structures on the property have changed, no new or trees, the environment is EXACTLY the same.
- The DC is installed on my detached garage, full and unobstructed view of the sky. The Dock sits on the opposite side of the house from the garage. While docked, HaLow connection = true, Signal can range anywhere from -74 to -91db (No idea why it is fluctuating that much in a fixed location)
- Wifi coverage around the house is excellent. -60 or better at the location of the dock.
Here is what is making me nuts. If I try to just have the core use HaLow, most of the time I can’t connect using the app (network problem) unless I use bluetooth. This makes sense if the HaLow signal is lower than about -78 to -80db. That pretty much makes the robot useless because this is a second home and I’m only there once every few weeks.
What I’ve tried in an attempt to resolve this:
- Checked all antenna connections, tried removing rubber washers, tried new antennas = no improvement
- I have a second data center, so I replaced the DC, keeping the same install location = no improvement
- Since I have excellent Wifi coverage and this is advertised as having multiple networking path options, I tried using Wifi. = This is great when I first turn it on and the robot is docked, I can start a plan and life is good UNTIL the robot returns to recharge. When departing to run a plan, it gets out away from the house, Halow picks up and it runs the plan. When it returns, it successfully docks, starts recharging, and then never reconnects to wifi, so its basically dead on the dock at that point since it hangs onto the HaLow connection that has unusable signal now where it was perfectly fine all last season.
Something has changed. I don’t know if Yarbo mucked up the HaLow radio transmit power on the two units in a firmware update or what, but HaLow performance has degraded since last season and the network path selection logic in core is pretty useless. When is Yarbo going to finally fix the networking stack in core so that it is able to properly make use of multipath networking to maintain and select forwarding paths properly? Its not exactly hard to validate all available network pathways and update routing based on simple tracker metrics. Heck, just look at or add MWAN to your software stack running in core.
Reinstalling everything because Yarbo made changes that broke an existing deployment isn’t really an option for me. For security reasons, there is only one location on my property where the dock can be placed and spending upwards of $1000 on a boom lift rental and all of the other necessary stuff to move the DC to the one other possible location it could be installed that would have better coverage isn’t practical. This shouldn’t be a problem if the network stack in core worked properly when managing multiple connections.
Check the cable connections inside the core and make sure they are tight. If so, I’d get a ticket opened so they can try and track down what is going on with that core’s HaLow.
I am having the same issues which I detailed in the forum. Besides all the troubleshooting, I have a control in that the second Yarbo is not affected. Still awaiting the response on my ticket. At this point I beginning to realize I shouldn’t have put money down on the Ms; not sure if I can get the money back on the two.
I’m now experiencing the same GPS signal issue, something I’ve never encountered before. It appears the antenna seal has failed and the top shell has separated. Upon closer inspection, I noticed rust has formed inside the antenna. It seems there may have been a bad batch of antennas manufactured with defective seals. See my original post here. Outdoor-Rated? My Yarbo Antenna Corroded, Failed, and BAD RTK Performance - #3 by Soofia
Hi there, I’m sorry to hear about the issue you’re experiencing.
Since the connectivity issues can be caused by many different factors, I can’t determine the root cause at this point. I’ve found your support ticket in our system, and I’ve added the information you shared here to the case for our team’s reference.
Kindly ask for your patience while our team investigates this further for you.
My initial guess is that it may be related to the RTK antenna seal, potentially causing rust or moisture buildup. If everything was working previously and no significant changes have been made, the issue is likely either antenna seal failure or software-related.
For clarification, I do also have a ticket open. No response yet in the support case but oddly enough, I’ve had it somewhat start working again. It’s not what I would call 100% reliable.
Just a note regarding the replies about the GPS signal. This isn’t a GPS signal issue, it’s a HaLow connectivity problem.
@bryan.wheeler I’ll check the internal HaLow connection the next time I’m onsite. I would expect a loose internal antenna connection to cause more problems while it’s out on the lawn and moving than when stationary, but it’s worth checking.
Toggle cellular on if you haven’t and if you reach your cap at any point, reach out to support and they should be able to reset that until it gets resolved.
@bryan.wheeler No cellular coverage where this mower is deployed, so unfortunately that’s not a fix. CHecked antenna connections and nothing was loose or damaged.
I kind of had it working entirely on wifi by placing some additional APs to get complete coverage of the property with good signal strength everywhere. After that, GPS stopped working properly (datacenter not only failed for Halow, but then also stopped working for providing GPS, so I had to switch to NetRTK). Magically after getting no answers from Yarbo, the HaLow started working again after the last firmware update got pushed and now I’m in the group that started having issues with mower pro failing with “Please wait while the blades reach the required speed”. Things are not going well this season.
Sorry to hear about the mower pro issue. Drop your ticket number here for the forum moderator to look into.
@Yarbo Ticket for Mower Pro failure is 225848
@bryan.wheeler I’m leaving it in a running job where the problem is active, so hopefully someone jumps on the ticket and investigates in a timely manner. This way its not just a screenshot of it in the app but they can actually diagnose it live. It’ll eventually drop the message and mow for a foot or two and then the problem starts again. Its on its third day of trying to mow an area of about 3/4 acre because it is constantly stopping with this message.
Regarding the “Please wait while the blades reach the required speed” issue, as we mentioned in the support ticket, we have already initiated the replacement process for you. Kindly ask for your patience while we arrange the replacement and wait for it to arrive.
As for the GPS issue, please continue monitoring the performance. If the issue happens again, please feel free to contact us and provide any related details so we can further investigate.
Thank you for your patience and cooperation.
