Good Day Everyone! BRAND NEW YARBO Owner and setting things up…
I started by looking thru the manuals then YouTube videos of people setting up their data centers.
I then started installing/drilling thru the house on a 27 foot ladder (not for the faint of heart) and then went and grabbed my data center for pre-assembly before heading back up to the roof.
Then, I noticed…. MY DATA CENTER ONLY HAS ONE PORT (POE/WAN)… NOT TWO like ALL the instructions and videos show (even in the manual that came with my YARBO system it shows two ports).
Can someone point me in the right direction… I cannot find anything about this or how to set it up.
Thanks,
Gary
Alpine Racing
Hey Gary,
Welcome to the community. The DC now only comes with the WAN port as the LAN port was not used. Connect the 30 meter ethernet cable to the WAN port on the Data Center and then into the POE side of the POE injector. Connect the LAN side of the POE injector with the 2 meter cable to your home router. Once your DC is booted, you should be able to proceed with the install process in the app. Activate your core, attach it to your home WiFi and wait for the firmware update to kick off. Should take about an hour. Once you see firmware version 3.11.7 in the app, you can install the DC and Docking Station in the app. There is a firmware update for the DC. You can access this under settings, Data Center Settings. Connect over bluetooth to the DC and check for firmware updates. After that, you can tap create map and be guided through installing the DC and Docking Station.
Hi Gary, welcome to the community and congrats on your new Yarbo!
Here’s the updated user manual that shows the current Data Center setup with only the WAN port. You can follow the instructions starting from page 18 to install and set up the Data Center: Yarbo User Manual | Yarbo Wiki
If you have any questions during the process or need clarification on any steps, feel free to ask—we’re happy to help!
