That sounds like my issue. Mine (aka Bumblebee) would intermittently connect again which is when I was able to check if it was connected to WiFi. Check that if you can get your phone to connect.
Thanks! I never knew you could scroll down. Thought it ended at the controller.
Yarbo is running now and was in the exact spot it “died” the other day and the Halo was reading -58.
So I assume it should have been fine the other night. But since I updated the wifi settings, it seems to be running as normal as it used too.
Hi @ric.cross You can try following Bryan’s suggestions first — they’re spot on. If the issue persists after that, please open a support ticket via support@yarbo.com so our team can check the logs and help get your Wallee back online.
Apologies, fat fingered that one. Got stuck in replying to another text and didn’t see the “Values” dropdown selection was selected when I quit reading the forum comments.
Now I can’t figure out how to delete the “values” flag on your comment
