Are these meant to allow you to run the snow tracks in summer? Any other uses/benefits? https://www.yarbo.com/products/plastic-filled-blocks-for-yarbo-tracks
You will be better off using actual summer lawn tracks, most of the damage occurs from the edge of the tracks while it’s turning so adding these will not help to protect your lawn. In my opinion, summer tracks need to be more rounded on the edge, during wet season leaf blowing- it really chews the yard up.
Also incremental parallel randomization of path should be implemented, my lawn settled and compacted exactly where Yarbo goes and now it’s not as flat as it used to be. Yarbo should move over an inch every time it executes same plan.
Have you tried rotating the routing? Should be able to set it to ~50* and get many different angles the grass is cut at.
These were for that but for the 23 model. They are not compatible with the 24 tracks. The 23 tracks were not swappable. So the inserts allowed it to mow less aggressively.
Aha! Figured it would be something like that:+1:![]()
