Power Board Error?
What’s this mean?
Just popped up, I’ve never seen this before.
If you hot swapped the module, potentially a false positive. To reset, unplug the battery for 5 mins and then hold the power button for 60 seconds when turning it back on. If the error persists, contact support so they can check out the power board.
Hey Bryan,
Thank you, I did what you said and the error cleared. Hopefully it stays that way!
I have never seen that ever before and was concerned something was seriously wrong, maybe it is and I’ll find out as time goes on or maybe it’s fine. I had not changed anything on it it was just out mowing but I was manually mowing a pathway up to my Quail pen when the error popped up. :person_shrugging:t3:
Someone else had a random error today too. Might just be a bug in the new firmware. If you’re concerned or just would like reassurance, submit a ticket with the times the error was present and they can check it out to be certain.
Well I’ve given it some time and it’s gone out and mowed a few times since in the error has not come back so I’m guessing it was just a bug or glitch that a rebooting pulling the battery for 5 minutes took care of.
Thank you for the advice!
