Power Board issue (again)
fired the Yarbo up to mow today and got the power board issue and message saying the yarbo was adjusting the blades. just sat there for 10 minutes before I sent it back to the pad. Still getting the power board issue message
Open a ticket if you haven’t already. Drop the ticket number here too so the moderator can check on the ticket also.
Are you disconnecting and connecting the module when the core is powered up? That can throw this error and cause other issues. Try pulling the battery cable for 5 mins and see if the error clears. If not, support ticket.
Hi there! You can try following the suggestion that Bryan shared earlier. If that doesn’t resolve the issue, please go ahead and submit a support ticket. Our after-sales support team will be happy to assist you and help get this resolved.
Tried the suggestion from Brian to no avail. Also, I always shut down the Yarbo before disconnecting the module. I submitted ticket #143502 just now
Well crap. I hope they get you a replacement in a hurry.
Bummer. Sorry your Yarbo is out of commission. Hopefully it will get replaced in short order.
The other thing you could try while you wait is holding the power button for 60 seconds.
Hi there, really sorry for the inconvenience caused. We’ve initiated the replacement process, and under normal circumstances you can expect to receive it within 7–10 business days. Due to the holiday, there may be a slight delay.
We truly appreciate your patience while waiting for the replacement process.
