sell the house and move south.
Seriously.
It just seems wrong that I can vacation in Alaska and the weather will be warmer than here in Michigan!
30F is miserable, wet, sloppy… double digits fahrenheit below ~25F ![]()
Here’s the album with the “poor man’s timelapse” there were some really satisfying clips where it comes back towards the camera and busts through the bank I’ll add soon…messing with Yarbo and patterns for the front yard…
Could you please check the notification center to see whether there were any notifications related to this behavior? If there aren’t any notifications explaining why Yarbo started that task, we may need to investigate the issue further.
Thank you for bringing this to our attention, and we appreciate your help in looking into it.
OK album updated, the last part when it’s busting through the snow plow bank is very satisfying!
This new update is awesome! Set ~.6 height first pass slow, max overlap, and 2nd pass .08”, fast to clean up. Probably could have used medium overlap on the 2nd pass, maybe next update![]()
Been kinda quiet here on the snow front…currently bringing in over 2kW of solar…
Also messing around with removing the skid runners, think they might stay off, just need to set your min heights up a bit, .20 for driveway ~.5 for yard
Just remember that those would dictate your approach angle instead of the scraper bar.
Yeah I was getting waves in the yard, I think the slop in the linear actuator/linkage, plus the skid runners was contributing. Also it seems to be able to push through deeper snow a little easier now too, assuming it also doesn’t hit some ice/snow pack. I tried removing some tracks from the wifes van a few weeks ago by running it multiple times and I even switched the direction and tried slope mode, it got high centered a couple times, and now I’m wondering if I try something like that again it might actually work. I’ve run the standard driveway plan a couple times without the skids and I like it
This is returning to the dock…Yarbo got drifted in
Please tell me again how great zero turns are…![]()
I’ll have to go out with the shovel and rescue it after this meeting
I agree with @ken.w.gregory, time to move ![]()
I could use that 2nd battery tray idea that’s been thrown around that mounts to the BBM and plugs into the rear port…both for ballast and runtime ![]()
You and me both! Would love to have that extended run time for sure. I could maybe even consider doing my neighbors driveways at that point.
That’s a lotta snowdrift! Poor Yarbo. All he wanted to do was get back to his charger and relax…
