Rover WiFi: Connect or Disconnect?
I’ve read & received (from Yarbo reps) discrepancies related to if the Rover WiFi internet connection should or should NOT remain connected at all times. Disconnecting WiFi makes sense after initial setup to prevent “toggling” between Halow & 4G & WiFi, but Yarbo reps have encouraged KEEPING the WiFi connection live as the Core is designed to use a pecking order order of preference based upon what signal is strongest.
This recommendation came about during discussions related to “Yarbo May Be Stuck” errors while the unit is searching for stronger Halow, 4G, or GPS, especially under tree canopies and OTA updates, and while minimizing 4G Smart Vision view restrictions to move the unit to a better signal area.
Can anyone confirm the BEST standard operating procedure related to Rover WiFi?
Thanks!
I tried WiFi at first but ran into too many issues where it was switching back and forth, same with Bluetooth.
I do not recommend it for most people unless you are having HaLow issues.
If your WiFi connection is stable and can provide coverage across your entire working area, it is okay to keep Rover WiFi enabled.
However, if your WiFi signal is unstable or you notice connection switching between WiFi, HaLow, and 4G causing unexpected behavior, you can follow the suggestion from others and turn off Rover WiFi to allow a more consistent connection experience.
The best setup depends on your specific environment and signal conditions.
HaLow and no WiFi to the core is what you want. HaLow is designed for longer transmission distances. Also, Yarbo seems to have handoff issues transitioning off WiFi. Handoff between HaLow and Cellular is the most reliable.
How do I disable core WiFi in latest app? I assume Settings → Network and then have to actually forget the network? Or can I toggle WiFi some way without forgetting my network?
You have to delete or forget the network. There is no switch to turn it off.
Bummer. Feature request.
HaLow handles all the data requirements. WiFi is essentially never needed. I have never once had my Core connected to WiFi since new.
Exactly. WiFi is known to cause issues and isn’t recommended for use by most users.
Ah, good to know. So even for firmware updates we should ignore the “connect to WiFi” app recommendation?
Correct. HaLow will handle it.
Yup. Zero need to connect your core to WiFi unless there is an unusual situation or problem that calls for it.
Let HaLow do the work and you’ll be happy that you did.
I still can’t understand why yarbo keeps telling people to turn on wifi.
That is a very good question. They need to update their support scripts. Turning on the core WiFi only adds complication and future problems.
Bluetooth can be the next one to shut off. Unless you have other issues bluetooth should be off also.
Yep. BT becomes an issue at the edges of its range. I’ve turned it off as well.
I have had it just walking behind the rover and it will cut in and out of bluetooth signal, stopping the core every time.
They seem to be using old 2023 scripts that they frequently copy and paste and also use WiFi synonymously with WiFi HaLow.
There is a time and place for WiFi.
Got a new or refurbished core, connect to home WiFi and let it update the firmware. After updated, delete the WiFi connection and proceed with setup.
HaLow not working, connect to WiFi and reach out to support. Whole yard covered with a good WiFi mesh system and you lose HaLow frequently in the yard, consider using WiFi. Otherwise, not a good idea.
Yes wifi is needed for original setup when there is no data center setup. But for regular usage, regular installations it should be turned off. I never said they should not have a wifi radio on the core, I am saying for normal usage it should be turned off.
