Hi all replacing an rtk cable that was sent to me from Yarbo but the video does not match. If you look at my photo it shows to take the 3 small screws out under the cover to thread the new cable in however it does not have 3 screw… Looks like a place for them but look like caps on them… MAybe they changed how it is done on the newer models? Thanks for the hel
There should be rubber plugs covering screws on the newer models. Remove the rubber plugs and the screws underneath and the yellow side should pop off and give some room to route the cable.
I just did this on my 2025 and noticed the same, there aren’t three screws under the yellow RTK/camera panel. It looks like they changed to a plastic retaining plug or something. What I did was took notice to how the old cable was routed through the gap between the aluminum and plastic. I pulled back the straight-end RTK antenna through the body and then disconnected the 90 degree end. I then pushed the new straight-end of the RTK antenna cable at the same angle into that gap were the old antenna cable was and used a pick hook tool, through the RTK antenna cable hole, to pull back the straight threaded end towards the hole. This worked really well because it redirects the antenna end, gently lining it towards the hole. It was easy to catch the hook took behind the shoulder of the antenna cable end.
